Monitoring | Stats
This section offers in-depth statistics on the load balancer’s performance, behavior, and interfaces. It is organized into three tabs:
Farms: Shows detailed statistics for each farm configured in the load balancer, including information about the backends, established connections, and pending connections.
System: Shows vital information about the system status, such as used memory, free memory, and total swap.
Network: Shows information about physical network interfaces.
IPDS: Shows information about the IPDS (Intrusion Prevention and Detection System) module like number of attacks or packets stopped by each rule type.
You can access more information through the provided links.
Next Article: Monitoring | Stats | Farms
