System | Logs
Log List
This section allows you to access the system logs to analyze problems and gather more information regarding the internal behavior of the appliance.
All the logs are collected in the /var/log directory and are rotated periodically. Old log files are compressed with the form syslog.*.gz. The higher the number, the older the logs are.
File. Log file name.
Date. The date when the file was last modified or the last log entry.
Actions. Use the following actions to manage the log files:
  • Show. Use this action to inspect the content of a given log file.
  • Download. Download the log file to the local storage.
