Custom LOAD BALANCING SOLUTIONS
Enhance Quality, Scale and
Secure Operations
SKUDONET is designed to enhance service quality with advanced load balancing capabilities. Allowing scale your infrastructure effortlessly while maintaining unwavering data security, ensuring the continuity of your operations.
Begasoft AG
Mawa Solutions
Cardzone
Schoolcraft College
Picosoft
SKUDONET Editions
SKUDONET offers two editions tailored to different needs: the Community Edition for testing and entry-level projects, and the Enterprise Edition for mission-critical environments.
COMMUNITY EDITION
Open Source Load Balancer
The open-source, free version of SKUDONET. Ideal for testing projects, learning environments, or small businesses that need an entry-level load balancing solution at no cost.
Learn More
SKUDONET Community edition login
ENTERPRISE EDITION
Application Delivery Controller
The enterprise-grade SKUDONET solution. It provides professional support, advanced scalability, and all the security functionalities required to protect and manage mission-critical environments.
Learn More
SKUDONET Enterrpise Edition new GUI 2
Application Delivery & Deployment Flexibility
Ensure continuous availability and adapt to any IT infrastructure with SKUDONET’s global traffic management and flexible deployment options.
SkudoCloud
Cloud Load Balancer
The SaaS version of SKUDONET, designed for organizations that need a cloud-based load balancer without investing in their own infrastructure. SkudoCloud is fully scalable, easy to manage, and completely maintained by our team.
Discover SkudoCloud
Security Features
Web Application Firewall (WAF)
Defense against OWASP Top 10 and other web attacks.
TLS/SSL Inspection
Secure encrypted traffic inspection with minimal impact on performance.
DDoS Protection
Mitigation of distributed denial-of-service attacks.
API Protection
Safeguard critical interfaces with dedicated security.
Support and Services Support & Services
SKUDONET provides different levels of support depending on the edition and needs of each customer
SKUDONET Support & Services
Community Forum.
Access the SKUDONET Forum to share knowledge and get help from other users.
Enterprise Service Plans.
Annual contracts that include updates, technical support or security guidance.
Knowledge Base.
A continuously updated resource with guides, best practices, and technical documentation.
Consulting Services.
Tailored assistance for organizations that require custom deployments or specific integrations.
contact us
Need Help Choosing the Version that Best Matches Your Needs?
If you need help choosing the custom Enterprise load balancer that best suits you and your business, our technical support team will advise you on everything you need.
