Monitoring | FarmGuardians | Create
Monitoring FarmGuardians
To create a custom Farmguardian check:
  1. Go to the Monitoring > Farmguardian section of the load balancer web interface.
  2. Click the Create Farmguardian button.
  3. Enter a name for the new health check in the Name field.
  4. Optionally, select an existing health check to copy from the Copy farmguardian field.
  5. Click the Apply button to confirm the new Farmguardian check.
Once you have created a custom Farmguardian check, you can Edit its parameters and Modify its behavior to meet your specific needs.
Next Article: Monitoring | FarmGuardian | Update
