Network | Gateway | Configurations
How to configure a default gateway in SKUDONET
A default gateway is a router that devices on a local area network (LAN) use to access the internet. In SKUDONET ADC, you can configure a default gateway for both IPv4 and IPv6 in the global routing table.
To configure a default gateway in SKUDONET:
    1. Go to the Network > Gateway page.
    2. Click the Configure button.
  1. In the Configure Default Gateway form, enter the following information:default gateway in SKUDONET
    • Address: The IP address of the default gateway.
    • Interface: The local interface that you want to use for outbound traffic.
  2. Click the Apply button to save your changes.
How to remove a default gateway in SKUDONET
To remove the default gateway configuration:
    2. Click the Unset button. You will be prompted to confirm
  1. Click the Confirm button to confirm. You will have removed the Gateway settings.
Next Article: System | Services
