Network | NIC
This section describes how to configure and use physical network interface cards (NICs).
The NIC Interfaces Table lists all of the non-virtual NICs that are available on the system.
Physical network interface cards (NICs)
These are the actions you can take on a selected network interface:
    • Bring up: This starts the interface and allows it to receive and transmit traffic.
    • Bring down: This stops the interface from receiving and transmitting traffic.
    • Unset: This removes all configuration settings from the interface.
    • Edit:Change the NIC configurations, such as the IP address, netmask, and gateway. One may only use the edit Icon after hovering over the Interface you’d like to edit. A pencil Icon will show.
The NIC List table shows the following information:
Name: The name of the physical network interface.
IP: The IP address of the physical network interface, if configured. The appliance supports both IPv4 and IPv6 addresses.
MAC: The MAC address of the physical network interface.
Netmask: The subnet mask of the physical network interface, if configured. The netmask must be configured at the same time as the IP address.
Gateway: The default gateway used by the NIC.
Status: The health status of the NIC, represented by a color:
  • Green: The NIC is up and running.
  • Red: The NIC is down or the link has not been detected.
Next Article: Network | NIC | Update
