DSLB | Farms | Create
To create a DSLB farm, follow these steps:
Go to the DSLB > Farms section.
    1. Click the Create Farm button.
    2. Enter a Name for the farm.
    3. Enter a Virtual IP for the farm. This is the IP address that will be used to load balance requests.
    4. Optionally, select a farm to Copy from the farm if you want to use the configuration of an existing farm.
    5. Click the Apply button to create the farm.
Once the farm has been created, you can begin configuring its properties in the next article.
Next Article: DSLB | Farms | Update
