Network | Routing | Rules | Update
Update routing rule
This view modifies routing rules to the smart routing module, those rules are conditions in the route system, if the condition matches then the matched traffic is passed to the indicated route table.
Table. The routing table to send the packets when there is a match.
From. Indicates the IP or CIDR (IP/mask) from where the packet comes.
Priority. A number to show the strength of a rule.
Description. A brief description of a given rule in each row.
Not match. A check which is used to negate a given condition. By default, it is disabled.
