System | RBAC | Users | Update
You can update the user-scoped parameters of an RBAC user to give or remove permissions.
To update an RBAC user:
  1. Go to the System > RBAC > Users page.
  2. Click the Edit button next to the user you want to update.
  3. Make the desired changes to the user’s parameters.
  4. Click the Apply button to save your changes.
The following parameters are available for updating RBAC users:
  • Group: Select the group that the user belongs to. A user must belong to at least one group in order to have access to the Load Balancer.
  • Max farms: Configure a max limit of farm creation for the indicated user.
  • Enable Web GUI Permission and Enable SSH Permissions: Enable each checkbox to give the user permission to access the Load Balancer through the Web GUI and SSH.
  • Enable ZAPI Permissions: Enable this checkbox to give the user permission to use the SKUDONET API.
  • ZAPI Key: If the user has ZAPI permissions, you must enter a valid ZAPI key in this field.
  • New Password: Enter a new password for the user.
  • Confirm Password: Re-enter the new password to confirm it.
Next Article: System | RBAC | Groups
