System | RBAC | Roles
RBAC Roles List
RBAC Roles allows the management of roles based on objects and actions. A role defines a set of permissions that are applied to a group. All users of the group inherit the group’s role. A role is a set of objects. Each object has actions and it can be enabled or disabled from the role.
The figure below shows an image with the name property to easily identify a selected role from the list
Name. A descriptive role name. It is used as a unique identifier for each role.
Actions. These are the allowed actions:
  • Create role. This action opens the roles creation form.
  • Edit. Opens a role configuration form.
  • Delete. Removes a role form and its configurations from the system.
Check out the Description of objects and their actions.
