System | Support Save
ZEVENET Support Save
The SupportSave section allows a user to generate a tarball gzip compressed file with all essential information about the local load balancer node status like its logs, configuration, and the system status in a certain instant. This information is used to analyze the current behavior of a node.
Click the Generate Report button to generate the file and download it to your PC.
This support save file will enable ZEVENET team to provide you with the best support.
