IPDS | WAF | Files | Create
To create an IPDS WAF file:
  1. Go to the IPDS >> WAF >> Files section.
  2. Click the Create File button.
  3. Enter a name for the new file in the Name field.
  4. Select the file type from the Type field. The available types include:
    • LUA script: This option allows you to set your own allowed scripts written in LUA.
    • Data file: The WAF system uses data files, such as blacklists and file extension lists, to extend the WAF rules.
    • Ruleset: The WAF system uses this file for defining Security rules, Seclang language modsecurity v3 is supported
  5. Enter the file content in the File Content field.
  6. Click the Create button.
The system will check the file content to make sure it is in the correct format. If the format is correct, the file will be created.
Next Article: IPDS | WAF | Files | Update
