LSLB | SSL Certificates | Generate CSR
To generate a Certificate Signing Request (CSR):
    1. Go to the LSLB > SSL Certificates section
    2. Click the Generate CSR button.
  1. Enter the following information in the form:
    • Name: A name for the certificate.
    • Locality: The city where your organization is located.
    • Country: The country where your organization is located, using the Alpha-2 code (e.g., ES, UK, RU).
    • State/Province: The state where your organization is registered.
    • Common Name: The Fully Qualified Domain Name (FQDN) of the server to be certified, such as domain.com, mail.domain.com, or *.domain.com.
    • Organization: The full legal name of your organization or company, such as Google Inc.
    • Division: Your department designation, such as “IT Department,” “Web,” or “Office.”
    • Email Address: Your contact email address.
  2. Click the Apply button.
A CSR file will be created. You can then use this file to obtain a trusted certificate from a Certificate Authority (CA).
Next Article: LSLB | SSL Certificates | Generate PEM
