Network | Routing | Tables | Configure
To configure Routing Tables in SKUDONET ADC:
  1. Go to the Network > Routing section.
  2. Scroll to the Routing tables list section.
  3. Hover over the routing table you’d like to configure and click the Gear icon labelled Configure.
  4. In the configure table section, drag and drop the interfaces from Managed Interfaces to Unmanaged interfaces or vice versa.
The image below shows the two groups of interfaces:
Managed interfaces are known to and used by the current routing table. The network associated with a managed interface will be reached directly by the routing table, instead of using the default gateway. If you do not need to reach the network interface through this routing table, you can move it to Unmanaged interfaces.
Moving an interface to Unmanaged interfaces will delete any route for that interface in the current routing table.
Next Article: Network | VPN
