Monitoring | Stats | IPDS
This section provides statistics for the IPDS module, listing the stats based on the Farm name and the kind of rules matching for each farm. Additionally, the information can be listed by rules, by hour and by remote IP.
IPDS information by Farm.
The following table describes the fields shown in the figure above:
Field Description
Name The farm name
Blacklist Matches done by this security module in the indicated farm
Dos Matches done by this security module in the indicated farm
RBL Matches done by this security module in the indicated farm
WAF Matches done by this security module in the indicated farm
Whitelist Matches done by this security module in the indicated farm
Total Matches done by the total of the security rules in the indicated farm
IPDS information by Rules.
This table provides information related to the IPDS rules matched by rule, the information is shown like a top 10 of Rules.
Field Description
Rule The rule name
Blacklist The total number of matches made by this rule
Dos The total number of matches made by this rule
RBL The total number of matches made by this rule
WAF The total number of matches made by this rule
Whitelist The total number of matches made by this rule
IPDS information by Hour.
This table provides information related to the IPDS rules matched by hour vs kind of rule, the information is shown like a summary of attacks by hour in 24 24-hour format of the current day.
Field Description
Hour Hour of the day
Total A summary of all the matches made by the rules
IPDS information by Remote IPs.
This table provides information related to source IP attackers detected by the IPDS module, the information is shown as a top 10 of attackers.
Field Description
IP source IP, identified like an attacker
Total Matches done by this source IP in all the security modules
Next Article: Monitoring | Farmguardians
