  1. Home
  2. Knowledge Base
  3. Community Edition v7.0 Administration Guide
LSLB | SSL Certificates | Info
This section is about viewing SSL certificate information. When you click on a domain name in the Common Name column,...
Monitoring | Stats
The Monitoring > Stats section is divided into two main sections: Farm Stats Network Stats Contents1 Farm Stats1.1 Backends1.2 Sessions2...
Login
Contents1 Access to SKUDONET Web GUI2 Changing Default Password Access to SKUDONET Web GUI To access the SKUDONET web GUI...
Dashboard
Contents1 SKUDONET Community Edition 7.0 Dashboard2 News SKUDONET3 System Stats4 System Information5 Traffic6 Farm List SKUDONET Community Edition 7.0 Dashboard...
LSLB | Farms
Contents1 Local Service Load Balancing (LSLB)1.1 Content Table Local Service Load Balancing (LSLB) The LSLB module balances traffic across pools...
LSLB | Farms | Create
This section allows you to create load-balancing farms. These farms can be configured in two ways: HTTP: This profile works...
LSLB | Farms | Update
Contents1 Update LSLB farm profiles1.1 Global Settings for L4xNAT Farm Profile1.2 Global Settings for HTTP Farm Profile Update LSLB farm...
LSLB | Farms | Update | HTTP Profile
Contents0.1 Global Settings for HTTP Farm Profile0.2 Basic Settings0.2.1 HTTPS Parameters0.2.2 HTTPS Cipher Options0.3 Advanced Settings0.3.1 HTTP error messages0.3.2 Headers1...
LSLB | Farms | Update | L4xNAT Profile
Contents1 Global Settings for L4xNAT Farm Profile2 Basic configuration3 Advanced configuration3.1 Protocol Type3.2 NAT Type3.2.1 NAT (Source NAT)3.2.2 DNAT (Destination...
SSL Certificates List This section lists all SSL certificates that are installed on the appliance and can be used by...
LSLB | SSL Certificates | Upload
How to upload an SSL Certificate on SKUDONET ADC To upload an SSL certificate to the load balancer: Go to...
LSLB | SSL Certificates | Generate CSR
How to Generate a CSR file in SKUDONET ADC To generate a Certificate Signing Request (CSR) file for your LSLB...
LSLB | Let’s Encrypt
SKUDONET Application Delivery Controller (ADC) can be used to manage Let’s Encrypt certificates. Let’s Encrypt is a free, open, and...
LSLB | Let’s Encrypt | Create
To create a Let’s Encrypt certificate for your LSLB farm: Go to LSLB > Let’s Encrypt > Create certificate section....
Monitoring | Graphs
The monitoring section connects all of the systems, network interfaces, farm services, and monitoring graphs. These graphs are essential for...
Monitoring | FarmGuardians
Contents1 Farmguardian2 Types of Health checks3 Farmguardian Actions4 Pre-configured health checks Farmguardian Farmguardian is a tool that helps you monitor...
Monitoring | FarmGuardians | Create
To create a custom Farmguardian check: Go to the Monitoring > Farmguardian section of the load balancer web interface. Click...
Monitoring | FarmGuardians | Update
SKUDONET uses simple health checks to monitor backends, but sometimes these checks are not enough. To address this, SKUDONET uses...
Network | NIC
This section describes how to configure and use physical network interface cards (NICs). The NIC Interfaces Table lists all of...
Network | NIC | Update
How to update the configuration settings of a NIC: Go to the Network > NIC page. Find the NIC that...
Network | VLAN
In today’s digital landscape, network security and efficient data management are not merely buzzwords but essential pillars of any organization’s...
Network | VLAN | Create
How to create a VLAN interface: Go to the Network > VLAN > Create VLAN page. In the Parent Interface...
Network | VLAN | Update
To update or modify a VLAN interface in SKUDONET: Go to the Network > VLAN section. Locate the VLAN interface...
Network | Virtual Interface
A virtual interface is a logical interface that can be created on top of a physical network interface card (NIC)...
Network | Virtual Interface | Create
How to create a virtual interface in SKUDONET: Go to the Network > Virtual Interface page. Click the Create Virtual...
Network | Virtual Interface | Update
To update or modify a virtual interface in Skudonet: Go to the Network > Virtual Interface page. Locate the virtual...
Network | Gateway | Configurations
Contents1 How to configure a default gateway in SKUDONET2 How to remove a default gateway in SKUDONET How to configure...
System | Services
Contents1 Local Services1.1 SNMP Service1.1.1 How to use SNMP in SKUDONET2 Remote Services2.1 DNS Services2.2 NTP Service2.3 Let’s Encrypt Local...
System | Backups
Contents1 How to Manage Load Balancer Backup Configurations1.1 Configuration Of Backups List How to Manage Load Balancer Backup Configurations This...
System | Backups | Create
How to create a backup file in SKUDONET ADC To create a backup file of the load balancer configuration: Go...
System | Backups | Upload
Uploading a backup on SKUDONET To upload and store a local backup file into the load balancer: Go to the...
System | User settings
To change your load balancer access credentials: Go to the System>Users section. Select the user whose credentials you want to...
System | Logs
Log List This section allows you to view and download the system logs. The logs can be used to troubleshoot...
System | License
Contents1 SKUDONET LICENSE1.1 Preamble2 TERMS AND CONDITIONS2.1 0. Definitions.2.2 1. Source Code.2.3 2. Basic Permissions.2.4 3. Protecting Users’ Legal Rights...
System | Support Save
How to generate a SupportSave file: Go to the System > Support Save section of the Skudonet web interface. Enable...
